progetto de1-soc
Re: progetto de1-soc
Postby ciapas » 31 May 2016, 22:22
non ho fatto quel tipo di verifica
comunque il software è questo, ci sono un pò di cicli for per i vari tentativi che ho fatto per settare il registro dell'audioevideo config
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/mman.h>
#include "hps_0.h"
#define LWH2F_REGS_BASE (0XFC000000)
#define LWH2F_REGS_OFST (0XFF200000)
#define LWH2F_REGS_SPAN (0X04000000)
#define LWH2F_REGS_MASK (LWH2F_REGS_SPAN-1)
#define BUF_SIZE 500000
int left_buffer[BUF_SIZE];
int right_buffer[BUF_SIZE];
int buffer_index = 0;
int fd_mem;
void* lwh2f_base;
int32_t* sys_id_addr;
volatile int32_t* audio_addr;
int32_t* audio_cfg;
uint32_t open_peripherals(){
// Map LWH2f bridge address space on a virtual address
fd_mem = open("/dev/mem", (O_RDWR | O_SYNC));
if(fd_mem < 0) {
return 1;
lwh2f_base = mmap(NULL, LWH2F_REGS_SPAN, ( PROT_READ | PROT_WRITE ), MAP_SHARED, fd_mem, LWH2F_REGS_BASE);
if(lwh2f_base == MAP_FAILED) {
close(fd_mem);
return 2;
// Evaluate all needed Soft IP base addresses, based on previously obtained bridges virtual base addresses
sys_id_addr = (int32_t*) ((uint32_t) lwh2f_base + ((uint32_t) (LWH2F_REGS_OFST+SYSID_QSYS_BASE) & (uint32_t) (LWH2F_REGS_MASK)));
audio_addr = (int32_t*) ((uint32_t) lwh2f_base + ((uint32_t) (LWH2F_REGS_OFST+AUDIO_0_BASE) & (uint32_t) (LWH2F_REGS_MASK)));
audio_cfg= (int32_t*)((uint32_t) lwh2f_base + ((uint32_t) (LWH2F_REGS_OFST+AUDIO_AND_VIDEO_CONFIG_0_BASE) & (uint32_t)(LWH2F_REGS_MASK)));
return 0;
// Close all peripherals opened from the application, by closing the virtual memory space mapping their registers
uint32_t close_peripherals() {
// Unmap LWH2f bridge address space
if(munmap(lwh2f_base, LWH2F_REGS_SPAN) != 0) {
return 1;
close(fd_mem);
return 0;
int main(){
int fifospace;
int i;
printf("open peripherals: %d\n", open_peripherals());
printf("accesso al registro: 0x%08x\n",*sys_id_addr);
*audio_addr= 0xc;
printf("verifica cancella fifo : 0x%08x\n", *audio_addr);
*audio_addr= 0x0;
printf("verifica disattiva cancella : 0x%08x\n", *audio_addr);
printf("statusregister1 cfg: 0x%08x\n",*(audio_cfg+1) );
for(i=0; i<100;i++)
fifospace= *(audio_addr+1);
printf("0x%08x\n", fifospace);//check if the LSB of the fifospace register are increasing
printf("accesso al leftdata : 0x%08x\n",*audio_addr+2);
printf("accesso al rightdata : 0x%08x\n",*audio_addr+3);
*audio_cfg=0x1;
printf("statusregister2 cfg: 0x%08x\n",*(audio_cfg+1) );
for(i=0; i<100;i++)
left_buffer[buffer_index] = *(audio_addr + 2);
right_buffer[buffer_index] = *(audio_addr + 3);
++buffer_index;
printf("bufferindex: 0x%08x\n",left_buffer[buffer_index]);
printf("bufferindex2: 0x%08x\n",right_buffer[buffer_index]);
printf("close peripherals: %d\n", close_peripherals());
return 0;
ciapas
Postby Leonardo » 04 Jun 2016, 19:24
Programmi la FPGA dall'HPS?
Postby ciapas » 04 Jun 2016, 19:39
e si , utilizzando il nios pur essendo piu semplice la gestione dell'audio andavo in contro ad altri problemi per la gestione poi dei dati tramite il linux , comunque tu credi che il mio sia un problema di clock?
ciapas
Postby Leonardo » 04 Jun 2016, 19:47
Domanda un po banale ma non si sa mai.. La compilazione va a buon fine SENZA ERRORI* di TimeQuest?
Ad ogni modo prova a descrivere rapidamente tutti i passaggi che hai fatto.
*Nel report di compilazione hai delle voci evidenziate in rosso come ad esempio Setup Summary?
Postby ciapas » 04 Jun 2016, 20:15
bè si ho alcuni errori nel time quest timing analyzer ma ho dato per scontato fossero per via dei vari componenti presenti sul ghrd che io non utilizzo(posto lo screen cosi magari mi puoi dire se sto dicendo una cavolata) .
Per quanto riguarda i passaggi intendi del programma o dell'intero progetto?
ciapas
Postby Leonardo » 04 Jun 2016, 20:28
Purtroppo hai dato per scontate troppe cose.. mai sottovalutare problematiche temporali con le logiche programmabili, non smetterò mai di ripeterlo.
Il GHRD è un progetto complesso e per metterci mano bisogna sapere bene quello che si sta facendo.
Per passaggi intendo dell'intero progetto, se stai facendo una relazione e hai già scritto qualcosa magari puoi postarla.
PS: Se ti colleghi alla chat del sito sono ONLINE per un pochino..
Postby ciapas » 05 Jun 2016, 10:09
in realtà il ghrd non l'ho modificato ho solo fatto delle aggiunte , comunque adesso provo a vedere un po il timing , per la relazione è in progetto, vi aggiorno appena ho novità, grazie mille per la disponibilità.
ciapas
Postby Leonardo » 05 Jun 2016, 10:18
Aggiunte = Modificato :D
Ad ogni modo ti lascio un link di un tutorial molto dettagliato per la DE1-Soc:
http://moodle.epfl.ch/pluginfile.php/1662462/mod_resource/content/23/SoC-FPGA%20Design%20Guide.pdf
