scusate ma ho perso del materiale e non riesco più a trovarlo...
Dove si trova il tutorial di ALTERA che come progetto fa il registratore audio con l'utilizzo delle HAL...
#include "altera_up_avalon_parallel_port.h"
#include "altera_up_avalon_audio.h"
#include "sys/alt_stdio.h"
/* globals */
#define BUF_SIZE 500000 // about 10 seconds of buffer (@ 48K samples/sec)
#define BUF_THRESHOLD 96 // 75% of 128 word buffer
/* function prototypes */
void check_KEYs( int *, int *, int *, alt_up_parallel_port_dev *, alt_up_audio_dev * );
* This program demonstrates use of HAL functions
* It performs the following:
* 1. records audio for about 10 seconds when KEY[1] is pressed. LEDG[0] is
* lit while recording
* 2. plays the recorded audio when KEY[2] is pressed. LEDG[1] is lit while
* playing
int main(void)
/* declare variables to point to devices that are opened */
alt_up_parallel_port_dev *KEY_dev;
alt_up_parallel_port_dev *green_LEDs_dev;
alt_up_audio_dev *audio_dev;
// open the pushbutton KEY parallel port
KEY_dev = alt_up_parallel_port_open_dev ("/dev/Pushbuttons");
if (KEY_dev == NULL)
alt_printf ("Error: could not open pushbutton KEY device\n");
return -1;
else
alt_printf ("Opened pushbutton KEY device\n");
// open the green LEDs parallel port
green_LEDs_dev = alt_up_parallel_port_open_dev ("/dev/Green_LEDs");
if (green_LEDs_dev == NULL)
alt_printf ("Error: could not open green LEDs device\n");
return -1;
else
alt_printf ("Opened green LEDs device\n");
audio_dev = alt_up_audio_open_dev ("/dev/Audio");
if ( audio_dev == NULL)
alt_printf ("Error: could not open audio device\n");
return -1;
else
alt_printf ("Opened audio device\n");
/* used for audio record/playback */
int record = 0, play = 0, buffer_index = 0;
unsigned int l_buf[BUF_SIZE];
unsigned int r_buf[BUF_SIZE];
int num_read; int num_written;
/* read and echo audio data */
record = 0;
play = 0;
while(1)
check_KEYs ( &record, &play, &buffer_index, KEY_dev, audio_dev );
if (record)
alt_up_parallel_port_write_data(green_LEDs_dev, 0x1); // set LEDG[0] on
// record data until the buffer is full
if (buffer_index < BUF_SIZE)
num_read = alt_up_audio_record_r (audio_dev, &(r_buf[buffer_index]),
BUF_SIZE - buffer_index);
/* assume we can read same # words from the left and right */
(void) alt_up_audio_record_l (audio_dev, &(l_buf[buffer_index]),
num_read);
buffer_index += num_read;
if (buffer_index == BUF_SIZE)
// done recording
record = 0;
alt_up_parallel_port_write_data(green_LEDs_dev, 0x0); // set LEDG off
else if (play)
alt_up_parallel_port_write_data(green_LEDs_dev, 0x2); // set LEDG[1] on
// output data until the buffer is empty
num_written = alt_up_audio_play_r (audio_dev, &(r_buf[buffer_index]),
/* assume that we can write the same # words to the left and right */
(void) alt_up_audio_play_l (audio_dev, &(l_buf[buffer_index]),
num_written);
buffer_index += num_written;
// done playback
play = 0;
* Subroutine to read KEYs
void check_KEYs(int *KEY1, int *KEY2, int *counter, alt_up_parallel_port_dev *KEY_dev,
alt_up_audio_dev *audio_dev)
int KEY_value;
KEY_value = alt_up_parallel_port_read_data (KEY_dev); // read the pushbutton KEY values
while (alt_up_parallel_port_read_data (KEY_dev)); // wait for pushbutton KEY release
if (KEY_value == 0x2) // check KEY1
// reset counter to start recording
*counter = 0;
// reset audio port
alt_up_audio_reset_audio_core (audio_dev);
*KEY1 = 1;
else if (KEY_value == 0x4) // check KEY2
// reset counter to start playback
*counter = 0;
// reset audio port
*KEY2 = 1;
